10-08-2020, 01:42 AM
halopower halopower is offline
Originally Posted by hodgey View Post
It will still be secam. A system converter may prevent the TBC from doing anything meaningful and leave handling of the unstable video signal to whatever does the conversion depending on how it's made.
You would need something that can handle SECAM to replace it. Ideally another TBC, or maybe you could get away with a DVD-recorder or AV receiver in place of it or maybe some other capture device that can handle video/audio sync well as notet.
O'What kind of receiver or DVD do you think?
black & white, intensity shuttle, secam
HD capture issues with Intensity Shuttle: audio sync, dropped frames? koberulz Capture, Record, Transfer 5 12-04-2017 08:43 AM
Blackmagic Intensity Shuttle doesn't report dropped frames metaleonid Capture, Record, Transfer 7 02-11-2015 09:48 PM
Blackmagic Intensity Pro Flicker Problem P4RL Capture, Record, Transfer 6 05-25-2012 11:05 PM
Black Magic intensity Pro Flicker Problem carlthulhu Capture, Record, Transfer 5 12-09-2011 05:12 PM
JVC HR-S9911U picture color fade problem. gzmachine Video Hardware Repair 7 03-05-2011 10:14 AM
