11-05-2019, 05:52 PM
Saporo Saporo is offline
Hi LS, u hope you ara fine.
I used the DMR with great results.... thankˋs again for all.
I need to ask you for some details, I have a pal-n tape to capture. I guess the better option is to buy a transcoder to convert the pal-n to ntsc. Considering I have a Panasonic ag 1980 in good shape and the DmR es15 FOR THE PassTrought.
Pal-n vhs vcr-> transcoder pal-n to ntsc -> ag1980->dmr-> usb710-> vdub with uffyuv.
This is the right path to go ?
Well I wait for your answer to put some light on this.
10-28-2020, 05:53 PM
I'm not really sure.
10-28-2020, 08:30 PM
Is there such a thing as PAL HUFFYUV or NTSC HUFFYUV? I would have thought not, the only difference being the frame size and frame rate?
Panasonic ES10 and ES15 the same for passthrough? colony Capture, Record, Transfer 16 10-03-2022 02:38 PM
Panasonic DMR-ES15 passthrough with failed DVD burner? DaveT Video Hardware Repair 1 09-27-2020 10:51 PM
DMR-ES15 passthrough functions? homefire Capture, Record, Transfer 9 05-14-2019 12:59 PM
DMR-ES10 / ES15 passthrough TBC setup? SuperS Capture, Record, Transfer 26 12-09-2018 02:20 PM
Does the Panasonic ES15 passthrough both NTSC and PAL? retartedted Capture, Record, Transfer 1 04-12-2017 08:45 PM
