Green AVT-8710 working correctly?
2 Attachment(s)
Hello! I recently purchased a green AVT 8710 and was wondering if this image is to be expected. I have a VHS player with line TBC coming, so these were without any other TBC.
JVC S6900 > ATI 600 > VirtualDub JVC S6900 > AVT 8710 (-2 Brightness) > ATI 600 > VirtualDub All connections using new Pearstone s-video cables, and the same level settings within VirtualDub. I ran the AVT for over 5 hours without any noticeable overheating. And both the VHS player and AVT are plugged into a PSU. It seems that there are some horizontal lines/flickering that is more noticeable when using the TBC. Is there something I can do to remove them or is this just the cost of using a frame TBC? Any help would be great, thanks! |
The TBC connections may be worn out. That's not normal.
1 Attachment(s)
Thanks for the reply. Uh oh, I was afraid something was off... I'll do another test once the VHS player with line TBC arrives, but looks like the AVT's going back.
I think for now this is my best option: JVC S6900 > ES10 > DVK-200 > ATI 600 > VirtualDub (all s-video) |
I loaned a then-not-working TBC to jwillis last year (or early this year). I'd given up. He saw what I did not: salt buildup on the connectors. I had gotten it cheap/free from California many moons earlier. Ocean salt air got into it.
After cleaning the TBC was "fine" (ended up being a "black" clone, not "green"). My lesson: look closer. Your lesson: ditto. |
Also, might be worth trying a different power supply if you can obtain a suitable replacement (see the other thread posted today about the specifics--note it must have the negative pole on the tip/center--most every other 12V adapter you'll find has a positive tip).
It may not solve your problem, but power supplies can cause all kinds of wacky issues so is worth a shot. |
Site design, images and content © 2002-2022 The Digital FAQ, www.digitalFAQ.com
Forum Software by vBulletin · Copyright © 2022 Jelsoft Enterprises Ltd.
