01-18-2021, 10:09 AM
jt_retro jt_retro is offline
Hey Folks
A pretty outdated concept I know, but what software would I use, in 2020, preferably on a modern mac, to stream an H264 file to DV tape via Firewire? Anything I Google talks about importing/capturing.
01-18-2021, 10:47 AM
What DV recorder do you plan to use?
Do "modern" MACs even support the older version of firewire/IEEE1394/iLink found on DV/HDV cameras and recorders?
01-18-2021, 11:23 AM
Either my Sony HVZ-Z1 camcorder, or my Sony DSR-11 deck.
I didn't know there were different versions of firewire, but a firewire to Thunderbolt adapter does exist from Apple.
01-18-2021, 01:53 PM
I don’t know about Mac but for pc you would use a certain version of Sony Vegas that still have the option Print to tape and the files will be transcoded first to DV/HDV and then put on tape, If you have compliant DV files you can use ScenlizerLive to print them on tape.
01-18-2021, 02:53 PM
^+1.
I cannot speak to MAC, however:
I currently use EDIUS 9.5 as my NLE, and I can Export the time line (i.e., Print to Tape) via firewire provided the project matches DV (frame/field rate and size), the hardware presets in the NLE are correct, and of course the PC is able to communicate with the recorder. That has become more involved these days with new PCs not having a IEEE1394 port, and MS abandoning the legacy IEEE1394 protocols with Win8 and newer, and newer software not speaking IEEE1394.
Best to research the forums dedicated to your software and recorder to check compatibility between T-bolt, adapters, and your gear. I have read that there are some issues with backward compatibility as the MAC evolves its own way.
Considerations when preparing a DVD for export to Europe? ehbowen Encode, Convert for discs 4 12-29-2020 11:47 AM
Best interlaced export formats for TV (VHS digitizing) fujrer General Discussion 2 04-25-2016 12:04 AM
How to export .srt file in Mac OS X? Patlamm Capture, Record, Transfer 3 02-17-2015 08:29 AM
Timeline to DVD Recorder? (Export DV from computer to DVD) couldbe Capture, Record, Transfer 5 09-17-2004 05:41 AM
