01-16-2021, 09:47 PM
waloshin waloshin is offline
What is the best codec to use with vhs and Hi8? Dv50?
Also does the Aja Kona take audio in through the sdi connector?
Lastly, I know head cleaner tapes are not reccomend for VHS but what about hi8 and minidv.
01-16-2021, 11:49 PM
The best way is to capture lossless AVI and encode to h.264, SDI is digital and Hi8 is analog, you need to use S-Video out from the camcorder to S-Video in to the Aja Kona. Cleaning tapes are ok if that's the only way, just make sure they are not too old.
Best AJA KONA capture software for IO LA? Formica Capture, Record, Transfer 2 08-23-2020 09:38 AM
Capturing VHS with the AJA Kona LSe card? Aerith Capture, Record, Transfer 61 08-14-2020 08:35 AM
Vhs capture --- kona aja lhi ... Not impressed!! johnnysh Capture, Record, Transfer 3 03-21-2020 02:17 PM
Kona LHi dropping frames from VCR with TBC? ryan42 Capture, Record, Transfer 6 06-25-2018 03:27 PM
Gspot Codec Analysis Tool - AVI codec info [DOWNLOAD] admin Encode, Convert for discs 1 03-19-2011 10:49 PM
