01-18-2021, 09:11 PM
adamstefan adamstefan is offline
I am trying to capture video from Sony DCR- HC21 (digital camera) using USB port (i do not have firewire port).
I have Honestech hardware AV to USB adapter. As Honestech software doesnt give de-interlacing, so use VirtualDUB software.
I used Windows 7, 32 bit to Windows 10, 64 bit. VirtualDUB ver. 1.10 and newer ver. VirtualDUB2_44282.
No mater how VirtualDUB is setup i cannot get more then 25 fps, only two settings: 720x480 MJPG and 480x320 YUY2 (images attached)
I have also very limited options in other pull down menus.
What am i doing wrong?
Is my adapter the problem?
01-19-2021, 11:17 PM
Where is that VirtualDub window from? I don't even know what that is.
- in capture AVI mode
- Video > Capture pins/filters (check both, I always forget which is which without looking)
- bottom right of main window, select fps.
- under Video > set Custom Format, change/verify capture resolution
Honestech is a really crappy card, barely above infamous Easycap or Elgato (aka Easycrap, Elcrapo). You will not have a good experience, nor good quality.
11-04-2022, 06:28 PM
traal traal is offline
I bought an EasyCAP card just to see how bad it is.
Confirmed, it only supports 25fps and maybe some lower frame rates. I couldn't get it to take 29.97. There are a two different ways to change it, but none of them worked (Video > Capture Pin, Capture > Settings).
YUY2 is 480x320 only. MJPG is 720x480, 640x480, or 480x320.
There are no brightness/contrast settings for capture, also no way to switch between composite and S-Video.
This is all using the DirectShow driver with composite. I can't use S-Video because 2 of the pins on the capture card are blocked.
Using the VFW driver, it supports 29.97 but there's no video, it's just a black screen.
Ok, I believe you now, LordSmurf. EasyCAP really is a piece of crap.
11-05-2022, 06:44 PM
Crazyates Crazyates is offline
If you're looking for a good alternative, I found the Avermedia EZMaker 7 to be decent. Worked great on my Win 11 system, and video quality was pretty good.
usb adapter, virtualdub capture
Elgato Video capture not recognized in OBS or VirtualDub? Cvatik Capture, Record, Transfer 10 08-02-2020 02:25 AM
How to capture interlaced video in VirtualDub? Gotanno Capture, Record, Transfer 9 06-18-2018 11:41 AM
Cannot get audio/video to sync in VirtualDub capture? Johncan Capture, Record, Transfer 4 03-22-2016 04:24 PM
Scrambled video in VirtualDub VHS capture? FLGuy83 Capture, Record, Transfer 5 12-01-2015 12:32 PM
VirtualDub - Can't Capture Video rckowal Capture, Record, Transfer 7 01-19-2010 06:49 PM
