03-06-2021, 02:02 AM
bluegrassdj bluegrassdj is offline
setup:
panasonic dmr-es46v -> s-video -> ati 600 usb -> virtualdub -> avi
sample capture attached. i've also attached one with reduced sharpening and contrast based no msgohan's feedback from previous thread.
(the other thread was about windows 10. since i'm using windows xp now so i'm starting a new thread)
the samples are original quality so they're really short.
You can do a lot to improve upon this latest capture. To start, I would set the ATI 600 sharpness control to 0 in its Proc Amp settings. The contrast looks overblown, and there is some line jitter, but fixing those issues may require more/different hardware.
i've seen screenshots of ati 600 usb proc amp online but i can't find it in my settings. i looked in catalyst media center but it's not in there. i adjusted the virtualdub levels instead.
i couldn't really tell that there was jitter. i disabled the overlay during capture in virtualdub. hopefully that had some effect.
03-06-2021, 10:33 AM
VirtualDub's Levels control is actually a hook into the standard "Proc Amp" in the WDM API, so it's the same thing.
Luckily, the ATI 600 on XP is one of the devices where Levels works. Some capture device/driver/OS combinations make this inaccessible.
The second clip looks better.
The line jitter I mentioned will be most visible along vertically-running lines (columns) in the video, like the credits sequence of a movie containing the capital letters "I" and "T", if you want to sample some more appropriate content.
03-06-2021, 08:56 PM
here's a clip of the credits. since this is from tv the credits aren't fullscreen and it's a bit hard to see line jitter. or maybe it's there and i don't really know what to look for.
i also noticed the other clips i posted were so big because they're raw, not huffyuv.
AIW AGP WinXP vs. ATI 600 or VC500 OS X differences? thefrog1394 Capture, Record, Transfer 20 01-24-2021 04:20 PM
How to improve quality of CED Videodisc capture? WestRGB Restore, Filter, Improve Quality 10 10-22-2020 01:04 PM
How to improve post-processing for VHS capture? anolegang Restore, Filter, Improve Quality 2 10-21-2020 05:22 PM
Recommend HDMI capture card for VirtualDub on WinXP? metaleonid Capture, Record, Transfer 38 11-05-2019 10:54 AM
NTSC gamut vs WinXP and Ati AIW card Mejnour Project Planning, Workflows 0 05-12-2015 02:07 PM
