1) Capture AVI or MPEG-2, interlaced
I can convert to mpeg-2 and the quality is great and no scanlines. I can convert the mpeg from the AIW to divx. I have my PS2 hooked up via svideo, and im using your faq on mpeg capture. IM using the high quality mpeg2 dvd settings that you have. Would it be different for games??
Also on the AVI huffy settings there is no interlaced option. But i did set it to 480. On mpeg capturing there is the drop down for interlaced.
Re-encode to the desired output resolution and run an adaptive de-interlace in TMPGENC PLUS,
ive used tmpgenc before, so ill get back to you on that.
Right now as it is, mpeg to divx seems to be the way to go, to eliminate scanlines. If i try to encode the mpeg using windows media encoder, i get errors.
Basically what im trying to do is find a good way to capture game tournatment footage, encode it for the web. my desired resolution, is whatever high quality and fast downloading can allow. more or less in the ball park of 30mb or less.
At the same time, my initial capture should be ready for editing. I know ive said this before, but mpeg capturing seems to work fine with no scanlines. But would mpeg be preffered for editing??? In your faq your suggest AVI mjpeg or huffy, but whew!!! mjpeg is horrible, and not only is huffy big, but the quality is what you saw.
im out of breath!!!!
thanks in advance...
- strangepork
