03-12-2021, 03:53 PM
videoconverter11 videoconverter11 is offline
I am trying to backup VHS tapes, by using my JVC S7800U to play them, then transferring the video feed using a RCA (yellow/white/red) to 3.5 mm cable. I set my Sony camcorder to pass through, but the moment I plug in the 3.5mm cable into the yellow ID-2 A/V "in" jack on the camcorder, a notable "hiss" or "hum" can be heard. I am wondering how I can get rid of this. Is this a copyright protection signal?
03-12-2021, 07:50 PM
BW37 BW37 is offline
Is the A/V cable the original Sony? If not, check the pin-out of the one you're using to see if it is correct. Sony & Canon used one standard but others (Samsung?) used a different one so not just any 3.5 mm cable will work.
03-12-2021, 07:51 PM
bookemdano bookemdano is offline
Post a small sample video with the sound. Hiss and hum are very different noises! A little bit of hiss is normal for VHS linear audio. Is it possible that the audio is being recorded at a very low level and you're maxing the volume on your computer?
If it's a hum then maybe it's a ground loop issue. Make sure the VCR, camcorder and computer are all plugged into the same power strip in the same outlet.
It's not any form of copy protection.
U-matic RM-690 remote control jack JonnyBravo Video Hardware Repair 0 02-20-2021 11:31 AM
Hi8 with DCR-TRV230 - capture DV vs. HuffyYUV? nullb Capture, Record, Transfer 13 02-05-2020 09:41 PM
Hi8 capture project with Sony DCR-TRV230? Liberty610 Capture, Record, Transfer 31 02-16-2018 09:46 AM
How to protect (not wear out) headphone jack on Mac laptop ? Sossity Computers 3 11-09-2011 04:42 PM
Strange light buzzing/hiss when headphones are in headphone jack Sossity Computers 6 02-22-2011 02:23 AM
