Originally Posted by hodgey
Is it this or this on you have?
Normall it should just be to connect the S-Video output from the NV-FS200 to one of the S-Video inputs on the dvd-recoder. You can use either the front or back one. Then select the the same input on the dvd-recorder. Note that the dvd-recorder will turn off the output if there is no input, so you have to play back something on the FS200 to get any signal from the outputs of the dvd-recorder.
It's also possible to use the scart inputs, though then you have to make sure to set both the vcr and dvd-recorder to use s-video on the scart input/output you are using.
Yeah the first link
Now i make it works thanks
But talking about quality is not so good
The eh55 make some lpixels
The elegato video capture connected with svideo to fs200 is far way more better
Maybe i should use the jvc dr-10 as encoding?
