-   -   Videonics MX-1 has no power supply? (https://www.digitalfaq.com/forum/video-capture/11646-videonics-mx-power.html)
0014x 03-22-2021 01:48 PM
1 Attachment(s)
Hi. I was able to find a good deal on a Videonics MX-1 mixer recently, but it came with no power supply.
I have been doing my research but there isn't much information out there on what power supply to get to ensure the mixer doesn't become damaged due to wrong voltages, etc.
On eBay, there's the following:
https://www.ebay.com/itm/VIDEONICS-1...y/301164528933
https://www.ebay.com/itm/Power-suppl...y/174619628735
And then on Amazon there's this:
https://www.amazon.com/Accessory-USA.../dp/B07B8RVK9S
For those of you who currently own this mixer, or did at one point, or know more about voltages, etc. What do you think I should do? Or, what do you recommend?
Thank you!
lordsmurf 03-22-2021 04:18 PM
Is it written on the MX-1 itself? If not, you need the manual.
Maybe another MX-1 owner can help you. It's not a suggested item, so not many here have it. But some do -- and often those are the same folks that saw it didn't work as a reliable TBC replacement.
latreche34 03-22-2021 05:05 PM
12voltvids demonstrated it in his channel:
https://youtu.be/HEXLlqJQ7Oc
Watch towards the second half when he turns on the frame synchronizer, you will be surprised how stable the image.
0014x 03-22-2021 09:31 PM
I'll download the manual and check it out.
I'll also have to check out a thread about reliable TBC replacements. Thanks!
