Thank you all for the views and responses.
Originally Posted by jwillis84
The VirtualDub 1.9.11 reference edition was 32 bit only and used DirectShow invented for 32 bit windows.
All synergies exist for 32 bit windows, not 64 bit windows.
Thank you jwillis for the detailed write-up. I will go with a reinstall of 32-bit W7 SP1.
.. at least "try" Win 10 the 32 bit edition.. if you have to have Win 10 or don't know how to use Win 7 or Win XP
I have been building myself desktops (though less frequently these days) since the days of Win98; I can manage my way around re-installing and working with W7. I will be capturing to a 1TB external drive and do the post processing on the Win10 partition. The current hardware is from ~2014 and supports UEFI.
We run Windows7 64-bit (I think!) on our capture machines without issues, but we're doing DV captures so to paraphrase Gertrude Stein "A Firewire port, is a Firewire Port, is a Firewire Port..."
I have been successfully digitizing my Hi8 tapes on my W10 64-Bit using ADVC-110; wanted to recapture them to raw 4:2:2 and so decided to go with USB-710.
