-   -   MMC software install (https://www.digitalfaq.com/forum/video-capture/12-mmc-software-install.html)
jrnyhead 02-08-2004 12:53 AM
Is there a way to install just the TV capture using MMC 8.2 without installing the other software like 'File Player, Video CD, CD Audio, LaunchPad, ect'?
The reason is, these apps run as defualt when MMC is installed and I wish to ues other software programs like PowerDVD or Roxio.
The MMC software does not let you choose not to install these apps. when using "Custom Settings"
admin 02-08-2004 04:15 PM
That may not be needed.
Is the problem that you simply like to double-click on the MPEG/AVI files, and it launches ATI MMC File Player or ATI MMC DVD Player instead of something else?
Or that it autoplays a DVD-Video when inserted in DVD-ROM, and you don't like that either?
jrnyhead 02-08-2004 11:24 PM
Yes.............
You nailed it right on the head!
This is what I don't like about MMC.
admin 02-09-2004 01:23 PM
2 Attachment(s)
Leave al of the ATI MMC components installed. They are fine. But like me, you do not want to be forced to use their sub-par DVD player or problematic file player (only the capture tool is good).
This is ACTUALLY a Windows issue.
You only have to do this fix ONCE (unless you re-install new media software):
To change this, HOLD THE SHIFT KEY and then RIGHT-CLICK on the file you want to open. In this example, I'll open an MPEG file.
Attachment 301
In Windows ME, 2000 and XP .. it also has the SUB-MENU where you can pick the CHOOSE PROGRAM option. Do this.
A screen will appear where you can choose the program YOU want to use in order to open ALL FILES OF THAT TYPE.
Attachment 302
In your case, pick WINDOWS MEDIA PLAYER (or MICROSOFT WINDOWS MEDIA PLAYER, depending on which version of Windows and WMP you have installed). Then tick the check box and click OK.
From now on, all files of that ype will play with THAT PROGRAM.
This works on ANY FILE and ANY PROGRAM in Windows.
If need more help, let me know.
You do not need to uninstall ATI MMC components, just don't use them. (They must be installed anyway).
