09-02-2021, 07:08 PM
shane7951 shane7951 is offline
I'm using virtualdub to transfer a vhs. I'm using huffyuv v2.1.1. I've tried to Google search but I'm not really getting a clear answer. An earlier attempt I had 2:4:1. What do these number mean?
09-02-2021, 10:56 PM
It's the ratio of the compressed filesize compared to the uncompressed video coming out of the capture device. So if it would be 75GB per hour in uncompressed format, at 2.5:1 lossless compression it's 30GB per hour.
09-02-2021, 10:59 PM
Awesome, thank you very much.
Capture card hardware compression filters -discovery jwillis84 Capture, Record, Transfer 12 07-16-2019 09:24 PM
Minimum PC spec for capture with compression? discmeister Capture, Record, Transfer 14 09-30-2018 10:26 AM
Capture and compression formats, VHS H.264? jeffpeck Encode, Convert for streaming 1 12-24-2017 11:20 PM
Capture formats, compression, 10-bit vs. 8-bit in Premiere CS5.5? Cingular Capture, Record, Transfer 3 06-08-2016 09:51 AM
Hardware compression capture device for MPEG-2 and/or H.264? naripeddi Capture, Record, Transfer 8 01-31-2014 05:59 AM
