09-06-2021, 11:38 AM
shane7951 shane7951 is offline
Preface: This is an AVI transfer using huffyuv from virtualdub. I captured the footage on an xp machine using a jvc hr-s9600u with an ATI USB 600. No filters were applied.
I could really use some help with this. I've been reading quite a bit but I'm honestly not sure how to accurately describe what I'm wanting to address. The light source seems to white out detail on colored shirts, faces, etc. I hate to take time out of anyone's day but I would greatly appreciate any assistance.
Below is a still and the Google Drive link is for a short clip.
Google drive clip https://drive.google.com/file/d/16Nw...ew?usp=sharing
09-06-2021, 01:20 PM
traal traal is offline
There are no "hot" pixels in the image (they are all well below 255), and the histogram doesn't cut off abruptly at the high end, so long story short there is no detail in the the white area that can be recovered.
09-06-2021, 01:26 PM
With the above, that looks like classic 'overexposure' - you've got the photographers nightmare, a dimly lit scene with a single bright source of light. Unfortunately, yes, if there's no valid detail in that you're screwed in the fundamental term.
There's ways of dealing with it, but they're slow, labourious and they're more akin to film colourisation than video technique, unless somebody more experienced in this comes along with a better answer you might have to 'paint' the information back in, and that's slow and requires a lot of talent. Much like photographic film, once it's "blown" there's no information there to recover.
09-06-2021, 01:30 PM
Bogilein Bogilein is offline
Try a different player.
http://www.digitalfaq.com/forum/vide...g-capture.html
The following users thank Bogilein for this useful post: lordsmurf (09-06-2021)
09-06-2021, 01:40 PM
I'd try another player as well. But for that exact scene, I'm not optimistic.
How to capture and output old analog sources easily? MrEx Capture, Record, Transfer 12 09-01-2020 07:46 PM
Less exposure/more detail with regular VCR than pro S-VHS VCR? history1 Capture, Record, Transfer 33 03-14-2020 07:41 AM
H.264 vs. MPEG-4 retains detail better? premiumcapture Encode, Convert for streaming 8 09-15-2014 09:53 AM
MainConcept Settings for VHS Sources jrodefeld Encode, Convert for discs 12 11-09-2011 12:06 PM
