09-12-2021, 10:20 PM
rprilenski rprilenski is offline
When I play the tape while in Overlay mode in VirtualDub 1.9.11 the FPS goes between 12-13. What settings do you think I need to enable to get the rate to 29.97? I attached a screenshot showing the bottom right settings that VirtualDub displays.
JVC SR-MV45 -> ES10 -> VC500 -> PC (I also have a WinTV-HVR 950 which has the same issue as well)
09-12-2021, 10:34 PM
How are all the others settings?
09-13-2021, 09:42 AM
Here are screenshots of the settings that I have enabled. Please let me know if you would like to see other setting windows and I will get it submitted.
Incorrect aspect ratio: Fix at capture or when restoring? juiceycow Restore, Filter, Improve Quality 2 12-30-2020 11:54 PM
VirtualDub Help - Video Standard & Frame Rate WestRGB Capture, Record, Transfer 0 08-14-2020 12:21 PM
Incorrect levels when compressing to x264 bilditup1 Encode, Convert for streaming 7 10-08-2015 06:10 PM
VirtualDub - constant frame rate vs. variable FPS? Zerowalker Capture, Record, Transfer 6 01-10-2014 04:02 PM
