09-14-2021, 02:36 AM
So I recently bought a Hauppauge USB Live2. For a few of my VHS, I have noticed that the audio is natively too loud.
I read in the link below that there seems to be a registry hack that could fix this, however I have not been able to find it.
http://www.digitalfaq.com/forum/vide...html#post60921
Lordsmurf, do you happen to know how to perform this registry hack?
I also read somewhere that registry hacks might need to be re-done every time the Hauppauge is re-inserted into my laptop. I do not seem to find where I read this (it could likely have been for another Hauppauge capture device). Would you happen to know if this is the case for the USB Live 2?
Thanks again.
09-15-2021, 09:35 AM
I don't think it exists for this card. It's specific to cards using empia chips while this one uses a conexant chip afaik. The drivers were lazily written, haven't seen any way to adjust the audio level on the conexant-based usb dongles in windows even though the hardware supports it. (The linux drivers let you adjust audio fine from what I remember, though the settings aren't stored on the dongle itself.) So, you need some external volume control or attenuator to avoid clipping. Alternatively, if you happen to be using a vcr or camcorder with a headphone out, those usually let you adjust the output volume.
09-16-2021, 02:21 AM
I forgot to mention it in my first post, but I am using an Asus laptop with Windows 10.
Well, that is quite unfortunate. At least there is a solution with external volume control as suggested. I might need to try that then.
Before doing so, the VCR I am using is a Panasonic NV-HS950. Would you happen to know if there is a way to adjust the level of volume through RCA-output on the VCR? I have not been able do that, but perhaps I am just missing something. I have a remote control for the VCR.
09-16-2021, 03:44 AM
You can't normally adjust the volume of RCA outputs on vcrs (though some older ones may have internal adjustments). The HS950 has a headphone output you could try though (using a minijack to rca adapter) which does have volume knob on the front.
09-17-2021, 05:19 AM
I'm not sure if this hack is the same as the ATI 600 USB audio registry edit. The audio is maxed at 256, and needs to be put at 128 (50%). The reason is due to no audio control in the driver, poor oversight by ATI and others.
09-21-2021, 08:48 AM
Thank you hodgey for the advice. Using the volume knob for the head phones output, the audio volume entering the Hauppauge is much lower, thus lower when capture. I tried to capture a few samples of the movie where the audio was clipped, and I seem to have found a suitable level now without any clipping. I turned the knob down almost 50 % as mentioned by lordsmurf.
I will try to capture the complete movie to see the results.
Thanks again.
Thread |
USB ATI TV Wonder 600 distorted audio hack?
billct97 |
1 |
12-13-2022 04:56 PM |
Clipped audio distortion from VirtualDub2, Hauppauge USB-Live2?
Morku |
5 |
11-11-2020 04:19 AM |
Registry hack for Tevion USB audio control?
kingbean |
13 |
10-31-2020 02:33 AM |
AmarecTV won't capture audio from USB-Live2?
koberulz |
8 |
07-31-2020 09:29 PM |
How to adjust very loud audio clipping during capture?
moxiecat |
6 |
03-07-2012 05:37 AM |
