Euh... The thing is, I am not suggesting those reads just for the fun of it, but simply because the question does not make much sense...
It's like asking " I want to cook food, but I don't want to learn how to turn on the cooking stove".
There is no such thing as "best handbrake settings PAL" or "high quality compression". These are very subjective, it is all about preferences. It really like cooking some steak. some of us are impatient, you want it done quickly, you eat medium, some of us are patient, they eat it well done or like eating pasta (Al dente vs fully cooked). It is a matter of test!
When you go to a restaurant, they give you a menu to pick and tweak sauces and extras as you wish. We don't have uniform food. It is the same with encoding.
Pick your preferences!
Do you want to keep the videos interlaced or do you want to convert them to progressive (hint: what device are you gonna watch the videos on) [this is an important question on which the encoding settings will depend]
- Are you willing to spend hours for 1 single encode or minutes?
- You say "high quality compression" how much compression do you want!? 1GB per hour of content? 10GB per hour of content, both are compression.
- What is high quality to you? as long as you can still see things moving? as close as possible to the original? in-between?
Also, Handbrake (and hybrid) do not have settings, what you set is the encoder. These programs are just interfaces. It's like having Alice and Bob, 2 Italians, who both speak Italian, but you are looking for Alice's language, without looking for Bob's language. When you learn Italian, it is Italian , you can just use it to communicate with any of the 2. Once you know what x264 settings you want (assuming you will use x264 and not one of the other codecs) you can use use x264gui (the simplest interface of all of them imho), MeGUI, Hybrid, Handbrake,
VirtualDub or whatever you want.
Normally what people do is: they read for a couple hours on encoding settings, try a combination 1 on a short clip, watch it, try another combination of settings, watch, compare quality, repeat few times until you reach something you are happy with between "encoding speed, quality, filesize(aka compression)"
Personally I don't care about speed at all, I would rather have smaller size, so I encode on "veryslow" or maybe "slow", rarely on "medium", never on fast, or superfast unless it is just to test the result of some avs script (which you won't need).
CRF: controls the quality, I consider the 23 (default) too high, and thus very low quality, (lower number gives better quality) My encodes vary between 10-20 depending on various factors (usually around 14-18). I know a lot of people who would go for 20+, I consider this low, others are happy with it, I know people who always fo 8-12, it's insane imo. You figure it out for yourself. (obviously the lower the crf value, the higher the quality but the bigger the file size)
hope that helps a little
