hello guys, i need your help!!
[...] The purpose is for making indie music videos.
Does that purpose really deserve our help in the Capture, Record, Transfer subforum?
Originally Posted by jsj2251
I'm using Sony ccd-sc7 hi8 model and I want to convert hi8 tape to digital file.
1. I looked around and found that I need to get a digital8 model with TBC, DNR, and S-Video functions.
Which model is the right choice?
This seems to me like clashing goals. You're going for a lo-fi aesthetic by shooting your video on Hi8 in current year, but then you're going to use our hi-fi methods intended for transferring old recordings?
Just use your recording camera as the player. Add a '90s video mixer like Videonics MX-1 to enhance the retro aesthetic of your editing and assist as a TBC (or "TBCish", at least) in your capture workflow.
Thank you for your answer!!
(I am not good at English so little wierd.sorry.)
Then, do I not need any other equipment other than old video mixer for lo-fi texture?
(like VCRs,any other TBCs,capture cards,DVD recorder,DV capture box,etc...)
Can you recommend a little more for the video mixer model? (If mx-1 is the best, it's okay!)
As you said, is this the right workflow?
hi8 camera->video mixer->desktop
Is there a place where I can get information about lo-fi conversion?
After Effects is cheaper and less effort, but there's a learning curve. I do not know if you're skilled in using AE?
If you want to get it 'right' in camera then disregard what I'm saying, but you could spend a lot of time and money getting frustrated to accomplish something you could do in 30 minutes in After Effects.
I use it a lot for cartoonish lo-fi material, but also to create a genuine-looking footage blend when we mix new and old.
I'm a huge Vaporwave nut, so this sort of thing interests me greatly.
there are various video editing tools and various plugins and filters in the world.
And we can use them to create a similar kind of analog feel.
But they're kind of clumsy, or awkward. It's like watching a well-made blockbuster CG.
I think the rough feeling of real analog comes from using analog equipment.
That is my recommendation, yes. Bearing in mind that I have never used one of these mixers, myself. I suggest doing a forum search for some more info.
Your original proposed workflow:
hi8 tape->digital8(TBC,DNR,S-Video)->capture card->desktop capture->encoding
My suggestion:
hi8 tape->any hi8 camcorder->video mixer->capture card->desktop capture->encoding
On the computer side, still use a lossless 4:2:2 capture solution since the goal is analog artifacts, not digital artifacts. If you want a specific capture device recommendation, let us know whereabouts in the world you reside.
Sorry, we've reached the limits of my knowledge on this topic. Seems there are a lot of tweakers on YouTube messing around with old mixers to create video art. Maybe they can help.
My suggestion:
Thank you for your detailed answer!
i live in south korea Please recommend a capture card!
and.. so Why use a lossless 4:2:2 capture card? Does hi8 tape use 4:2:2 sampling? Isn't that a digital term?
And I have a capture card called I-O DATA GV-USB2. Is this useless to me?
Absolutely not! I love my GV-USB2. I'm on Windows 10 64bit and the GV is bulletproof. It always just works. Quality is on a par with the Pinnacle 710-USB and the Startech USB3HDCAP capture sticks.
The setup is in Japanese but if you follow this guide:
For capturing, I use Virtual Dub 1.9.11, capturing into HUFFYUV or Lagarith lossless format. That will be in 4:2:2 colour (Don't ask me how or why that's good! ).
Can I ask you a few questions?
I have hi8 camera, usb capture card,
There is no VCR or TBC device
If I need them, do you have any model recommendations?
