Quantcast Current capture device recommendations? - Page 3 - digitalFAQ Forum
05-07-2022, 11:21 PM
autephex autephex is offline
I've got the Hauppauge Live2 USB in now and have done the convoluted install of huffyuv2 for Windows 10 to get it to show up in available video codecs. Everything appears to be setup now. Going to try to do some captures tomorrow if I can get some free time in.... If there are any particular settings I should be aware of, would really appreciate the tip offs. Thanks
05-08-2022, 04:37 AM
lollo2 lollo2 is offline
AmarecTV 3.10 Settings
Graph 1(Device)	Device Setting -> Decoder video PAL_G (*)
	*w=720, h=576, fps=25,00, fcc=YUY2, bit=16
	*sample=48000, bit=16, ch= 2
Recording	Frame rate 999
	Video Compressor Other Codec HFYU
Advanced	X Wait for exit
	Video Renderer Setting
	X Auto
	X Change a "HDYC" to "UYVY"
	Record Setting
	X Use Null frame.
	X Match the start timing of the audio with a video.
	X Make a report file.
capture, hauppauge 610 usb live-2, vhs
Recommendations for VCR and capture card? mlsnag Capture, Record, Transfer 7 04-26-2022 07:35 PM
Recommendations to capture VHS tapes to HDD? swm79 Capture, Record, Transfer 17 03-20-2021 12:55 PM
TBC recommendations for Hi8 capture using Sony EV-C100? theugster Capture, Record, Transfer 8 08-15-2020 10:47 AM
Re-thinking my current capture cables and power set-up! rocko Project Planning, Workflows 14 07-23-2015 06:25 PM
Hi8 Capture HW/SW Recommendations djam0000 Capture, Record, Transfer 8 02-24-2010 10:24 PM
