Originally Posted by Rookie20
Has anyone used a pinnacle 710 usb device to transfer DV tapes to a pc? If so what version of windows works the best. At This time I just want top transfer the files to a hard drive to protect from the tapes deteriorating.
Glenn
I don't know how the pinnacle device you have works.
I work with a PCI Firewire card, I'm fine with it and the quality is perfect. You would only need a Firewire card, the firewire cable and a camcorder.
I use windows 10. For DV format I use sclive software and/or Adobe Premiere, for HDV format I use Adobe premiere because the HDVSplit soft has had results with corrupt files.
To compress the files to codec .H264 I use Adobe Encoder
