Im using virtual dub to capture from my D8 camera with firewire. I read on this forum that virtualdub2 has its problems and to use VirtualDub 1.9.11, i downloaded VirtualDub 1.9.11, I've read everywhere the huffyuv codec is the best for capturing footage (i have over 20tb of storage so file size isnt a problem) but I can't seem to install the Huffyuv codec, I've tried everything and nothing works, I'm on a windows 10 64bit system.
I tried using the method in this link http://www.digitalfaq.com/forum/vide...l-huffyuv.html and I get a copy error |
Run everything as "Administrator"
I tried that and i didnt get the error message but the codec doesnt show up in virtualdub
Install 32-bit HuffYUV for capture: http://www.digitalfaq.com/forum/vide...html#post81490
Or follow this: http://www.digitalfaq.com/forum/vide...html#post81619 |
Lagarith. None of this Huff malarky.
