Quantcast Replacement for ATI AIW 9800 Pro? - digitalFAQ.com Support Forum
Go Back   digitalFAQ.com Support Forum > Digital Video > DVD Project Help > Capture, Record, Transfer
05-06-2009, 04:33 PM
from e-mail...
Hello
My (second in 8 years) ATI AIW 9800 Pro is beginning to fail. I need your recommendation for a replacement as they are getting hard to find. I capture video from my Satellite DVR using MMC 8.5, at 720x480, 8mb/sec, MpegVCR and Ulead DVD Workshop v2.0. It was such a bear to set up, I would like to find a capture card that will still use this software. (Visiontek or Diamond?). I appreciate your help.
Thank you
This is a short and easy answer: eBay.
At this very moment, I see plenty of 9000-series cards available. Unless you're trying to play video games from a few years ago, the "9800" part does not matter much, as that is simply the graphics engine. The 9000-series all had the Theatre 200 MPEG capture chipset that you're after.
I assume you're still using an AGP-card computer.
For example, here is a nice looking card: http://cgi.ebay.com/ATI-All-in-Wonde...3%3A1|294%3A50
If you need something else, let me know.
A secondary suggestion would be the Hauppauge series cards, which are PCI MPEG hardware encoders. If you don't need to clean up the video any, and don't mind learning new-but-similar software (sort of close-ish), then these work. The PVR250 and PVR350, which can be more costly AND harder to find than ATI AIW 9000 series.
__________________
If this site has been as helpful as a book or magazine, then Donate a few Dollars or Upgrade your Membership.
ATI 9800 AIW manthing Capture, Record, Transfer 8 07-05-2005 01:22 AM
9800 AIW black & white prob manthing Capture, Record, Transfer 6 06-26-2005 06:48 PM
AIW 9800 Pro MV Edye Capture, Record, Transfer 3 11-21-2004 05:41 AM
AIW 9800 PRO strangepork Capture, Record, Transfer 10 10-21-2004 10:44 AM
All times are GMT -5. The time now is 11:34 AM  —  vBulletin Copyright © 2011 Jelsoft Enterprises Ltd  —  SEO by vBSEO
