DVD capture with Vegas, which codec ?
Trying to increase my knowledge … for conversion of SVHS tapes, edit in VMS, and eventually onto DVD.
Read on the “Digital Faq” that you should capture using uncompressed (YUY2) or Low Compression codec (HUFFYUV) I’m using a DV capture device (ADVC300) , and running the capture feature on Sony Vegas, this defaults to DV or DVD …. I select DV and looking at resultant saved file details is shows: Format : Digital Video Codec ID : dvsd Codec ID/Hint : Sony Duration : 1h 18mn Bit rate mode : Constant Bit rate : 24.4 Mbps Width : 720 pixels Height : 576 pixels Display aspect ratio : 5:4 Original display aspect ratio : 4:3 Frame rate mode : Constant Frame rate : 25.000 fps Standard : PAL Resolution : 8 bits Colorimetry : 4:2:0 Scan type : Interlaced Bits/(Pixel*Frame) : 2.357 Stream size : 15.8 GiB (95%) Should I be looking at changing the codec to HUFFYUV ? …… Set up is PAL SVHS VCR - TBC - ADVC300 - IEEE1394 PC |
By using a DV capture device, you're forced to use DV. There are no other options.
