02-08-2010, 02:26 PM
Superstar Superstar is offline
I'm confused about my notes on this subject so I wanted to double check it..
For videos that I am NOT going to encode, I'm just going to capture them, and then take them straight into Workshop, and make them into a DVD.
In my capturing program, WinTV, should I make the settings as follows -
Variable Bitrate 3900 (these numbers are just examples)
Bitrate Peak 4900
Video Resolution - 352x480, or should it be 720x480? I have both wrote down, and that's where I'm confused. At first guess, I would think it would be 352x480 since I won't be encoding them, but I wanted to double check.
Audio- 256
02-09-2010, 08:01 PM
Still need this answered, thanks.
02-10-2010, 07:54 AM
Bitrate Peak 4900
Those bitrates are in the "superbit" range, if used with 352x480. It's very high, meaning the picture should be fairly artifact-free from most sources. You're looking at about 2.5 hours, using those settings.
If you did that with 704x480 or 720x480, then your video would be very blocky. That is a very high compression, a low bitrate allocation. Not good for 720x480.
Definitely 352x480, yes.
Remember that this topic is covered on the introduction to capturing and encoding video near the bottom of the article.
Examples of Jitter Removed from videos lordsmurf Restore, Filter, Improve Quality 6 11-19-2009 05:48 AM
Videos into DVDs... Superstar Capture, Record, Transfer 27 01-18-2009 11:49 PM
How to put videos on my iPod ? gatch72 Videography: Cameras, TVs and Players 0 11-05-2006 12:15 PM
Newbie help - take recorded videos and stills, put them together mags102 Project Planning, Workflows 4 08-11-2006 02:18 PM
Inserting writing on videos? emokid Edit Video, Audio 1 07-08-2006 04:39 PM
