Quantcast Using Liteon DVD recorder to re-record scratched disc? - Page 2 - digitalFAQ.com Support Forum
Go Back   digitalFAQ.com Support Forum > Digital Video > DVD Project Help > Capture, Record, Transfer
02-27-2010, 03:50 PM
cyber-junkie's Avatar
cyber-junkie cyber-junkie is offline
I assume it's a DVD5 but don't know, do you need to check that for any disk you want to copy? And if so is that info gspot will provide?
It copied as a videoTS folder with the vob files inside.
02-27-2010, 04:18 PM
Go to "My Computer" (Windows explorer), right click on the DVD drive, go to properties. How big is the disc?
__________________
If this site has been as helpful as a book or magazine, then Donate a few Dollars or Upgrade your Membership.
02-27-2010, 04:20 PM
5.89 GB size
02-27-2010, 04:29 PM
That's a dual layer disc. You have to do one of two things.
1. Copy DVD 1:1
Rip it again with DVD Decrypter, and be sure to go into the program settings and enable the MDS file creation checkbox. When it rips the disc to an ISO+MDS file pair, then burn the new disc with ImgBurn. You'll pick the MDS file as the thing to burn. You need to use a Verbatim DVD+R DL disc.
2. Shrink Copy.
You'll rip the disc in DVD Decrypter, then use DVD Shrink to "shrink" the DVD to fit a 4.37GB DVD-R or DVD+R single layer disc. You may lose some quality with this method, it's not 1:1. How much quality loss is noticed (if any) depends on how bit-saturated the original retail disc is.
__________________
02-27-2010, 06:10 PM
MDS create file box checked, re-ripped to folder I created on HardDrive, ripped with no errors, put in DL DVD disk, try to copy and there is no MDS file, did this twice, it is not creating the MDS file, even chech file extensions and MDS is checked there too.
02-27-2010, 06:18 PM
You see filename.ISO, but no filename.MDS?
Hmmm....
Well, you can always just try burning with ImgBurn, and let it guess at where to put the break. There's usually not a lot of locations, and ImgBurn is usually correct.
If you play the disc, and it can't access the second layer, then you'll know there's an issue.
__________________
02-27-2010, 09:18 PM
There is no .ISO or .MDS, it has the vob files and a couple of other type of files...like it just copied what's on the disk, maybe it didn't decypt....but it did burn using dvd shrink.
02-27-2010, 09:43 PM
You ripped it in file mode --
File mode takes the VIDEO_TS folder, and all the IFO, VOB and BUP files inside of it. This is not what you want to have.
ISO mode create an ISO and MDS.
You know, up at the top of the program ... FILE, EDIT, MODE
and then be sure you're in ISO mode.
This is in DVD Decrypter.
Although DVD Decrypter can burn, you're better off using ImgBurn to burn.
__________________
02-28-2010, 03:49 PM
Ok...I should have figured that out...
What is meant by "no reference position found" ? I thought the disk could not be played because dirty/scratched but I guess this is the reason it won't play and is there anything that can be done?
02-28-2010, 04:27 PM
The dvd drive in the computer shows 0 bytes...do factory movie disks get out with nothing on them?
02-28-2010, 09:10 PM
I don't know that I've ever had that error message.
If this retail DVD is copy protected, it may use a method that DVD Decrypter cannot understand. DVD Decrypter was discontinued several years ago -- the developer decided to concentrate more on the burning aspect (hence, ImgBurn) and not so much on the reading/ripping of discs.
Newer software, that can detect newer protection schemes, is DVDFab 6, and you can use it in the free "HD Decrypter" mode. Download it here: https://secure.avangate.com/affiliat...www.dvdfab.net
0 bytes is probably related to the protection. I can't think of a likely scenario that would create a blank pressed DVD. It's not like a burn, where you could overlook one or get a lead-in burn fail that goes unseen. A blank press? Nah.
__________________
LiteOn (Ilo, Daytek, Gateway) DVD recorder hacks admin Home Entertainment and Videography 28 02-01-2012 06:04 AM
LiteOn DVD recorder hardware modifications admin Capture, Record, Transfer 1 03-05-2009 02:57 AM
DVD recorder repair service: Apex, Cyberhome, Digitrex, Liteon admin Capture, Record, Transfer 0 03-04-2009 08:29 PM
Can't Record From DVR to DVD Recorder rob0466 Capture, Record, Transfer 7 02-19-2009 06:52 AM
LiteOn DVD recorder for sale [SOLD] lordsmurf Marketplace 0 05-10-2006 08:00 PM
All times are GMT -5. The time now is 12:00 PM  —  vBulletin Copyright © 2011 Jelsoft Enterprises Ltd  —  SEO by vBSEO
