07-30-2010, 10:41 PM
Superstar Superstar is offline
I recorded a show off of tv in SP mode..and the show is 1 hr, and 16 mins.
When I encode it, what bitrate would you suggest I use? I know it'd be constant bitrate since it's under 2 hrs, but I wanted to ask because I captured it in SP mode, and wasn't sure what the bitrate rules for that would be.
07-31-2010, 02:37 AM
As per past conversations, this length is still not necessarily going to be CBR (constant bit rate). I would still be using two-pass VBR (variable bit rate) for a 75- to 90-minute piece, that's going to be put to a single-layer DVD-R/DVD+R/DVD-ROM.
Again, I would refer you to use calculators.
For 75 minutes, look at 7500kbps (7.5Mbps), max 9000k, 384k audio stereo AC3 or MP2. I'd say you could use CBR if your content quality is really godo, and lacks lots of detail and/or fast movements. But for the best quality, VBR is suggested for anything over 1 hour.
ONE HOUR, not two hours.
This assume you're restoring or doing something else to the video, that necessitates re-encoding it. If there is nothing to be repaired or edited (not including removing segments, like commercials), then there is no benefit to re-encode. Just leave it alone, use it as-is.
Re-encoding to higher bitrate will not increase quality, and it might even reduce the quality some more, depending on content.
VCR Picture control settings to use while capturing Steve(MS) Capture, Record, Transfer 2 07-18-2010 02:34 PM
Capturing Settings for Non-Encoded Videos Superstar Capture, Record, Transfer 2 02-10-2010 07:54 AM
Videos into DVDs... Superstar Capture, Record, Transfer 27 01-18-2009 11:49 PM
How to put videos on my iPod ? gatch72 Videography: Cameras, TVs and Players 0 11-05-2006 12:15 PM
Inserting writing on videos? emokid Edit Video, Audio 1 07-08-2006 04:39 PM
