09-08-2010, 05:14 PM
monks19 monks19 is offline
hi, i'm looking for some remote controls that goes with those devices:
Panasonic:
DVCR (mini DV)AG-AG-DV1000
SVCR AG-3200
SVCR AG-1960
Magnavox CMVD 2206 (combo vcr/DVD)
if anybody knows where the proper controls of any other(s) that can fit with these, please let me know.
thanks to answer
09-09-2010, 05:20 AM
Juan-ito Juan-ito is offline
Just a thought,
you could try buying a universal remote that can be programmed for the models you are asking about. Some such as those from logitech can have several remotes on the same controller and they have an online database of many models.
Might be the easy way out rather than trying to find the individual remotes.
Or stand up alot
09-09-2010, 05:29 AM
If the Panasonic S-VHS AG-1960 is anything like the AG-1980 model, then there's almost nothing on the remote anyway. All of the important controls are on the deck itself, and only on the deck itself.
09-09-2010, 05:33 AM
True, there is a control already on the deck itself on the ag-1960. But what about the other decks ?
thanks to answer
09-10-2010, 11:09 AM
ok, sorry. my question wasn't correctly asked.
For these decks, is there any remote i can find so i can use them in their full capacity:
Panasonic DVCR (mini DV)AG-AG-DV1000
Panasonic SVCR AG-3200
thanks to answer
09-27-2010, 05:55 PM
I don't know that the Panasonic SVCR AG-3200 needs a remote any more than the 1980 does. Not familiar with those others. I'd have to suggest hitting up Google searching, or possibly eBay for remotes. You may have to go with universal remotes that can be programmed.
Using KVM to control multi computers admin Computers 5 01-08-2011 01:53 AM
VCR Picture control settings to use while capturing Steve(MS) Capture, Record, Transfer 2 07-18-2010 02:34 PM
Mac video capture devices? lordsmurf Capture, Record, Transfer 0 05-09-2009 11:20 AM
SIMA devices available [SOLD] lordsmurf Marketplace 0 05-10-2006 07:57 PM
Capturing Devices other than Cards ishmot Capture, Record, Transfer 4 04-07-2005 05:02 PM
