02-12-2011, 06:34 AM
HidenSeek HidenSeek is offline
hello! I saw your name on the videohelp forum so I wondered if you could help me?
I want to digitize the old hi8 tapes that I have. I went searching on the great internet for some advice on how to do so. I've seen you recommending the ATI TV Wonder 600 usb. so I searched for it on ebay and found that there is also a card with the same name. Is one better than the other performance wise? or is it just that the first one is portable while the other is stationary?
btw I have vista 64bit, and also all my tapes are PAL (my camcorder too). Will this card work for me?
cheers!
03-17-2011, 02:21 AM
I'll reply to this, piece by piece...
Yes, I post in several places online, between projects -- usually while waiting for computers to process video. The best place to reach me will always be here at digitalFAQ.com.
Be sure to also read this: http://www.digitalfaq.com/forum/show...ered-1530.html
And then post tech questions in the forum, not PMs. We try to give advice in public, so that as many people as possible can benefit from the advice. We try to avoid "hiding" advice in emails or private messages.
Thanks!
I believe so, yes. However, as a disclaimer, I personally have only used the 600 USB cards to date. But others -- reliable sources, not random people -- have stated it's the same card. And I believe them.
Yes. There are Vista 64 drivers, at least for the USB version -- and therefore probably for the internal card as well. I've used the card on a Vista 64 system -- quite regularly, in fact. Works fine. It does not capture PAL MPEG, but you can capture PAL lossless AVI in VirtualDub. No issues, looks great.
Randomly, some USB 600 users have AGC errors, and there's one post here on this forum right now where a member is experiencing it. However, on my card, no such problem has been observed to date. You don't hear about it very much, which either means (1) it's not widespread and is therefore not a flaw of all cards, or (2) people just deal with crappy quality. Of course, I would never do #2, so I tend to believe it's #1. I'm not blind to IRE/luma issues.
Hope that helps.
Please reply here, to this post, if you have more questions.
03-17-2011, 06:07 PM
thanks I was thinking about using virtualdub to capture lossless avi(with huffyuv). I want to store them on a hdd for safe keepings and preserve the original quality as much as I can.
about buying the usb stick, I see you often post a link to this
http://www.amazon.com/Tv-Wonder-600-...=pd_rhf_shvl_2
however it's currently out of stock, but I guess this is the same stick just bundled with more stuff?
http://www.amazon.com/gp/product/B00...=AQS23MB45XEET
What internal audio cable for ATI All In Wonder? history1 Capture, Record, Transfer 9 03-05-2022 05:47 PM
LCD panel internal mountings safe? darky8 General Discussion 2 07-16-2016 12:34 PM
ATI All In Wonder 4-pin internal audio cable? Father-of-Ash Capture, Record, Transfer 5 07-03-2016 01:48 PM
Internal TBC VCR or HQ Non-TBC VCR + Panasonic DMR-ES10? LukeS Restore, Filter, Improve Quality 1 10-25-2011 04:06 AM
What type of internal audio cable for my AIW 7500 and which sound card!? rappy Capture, Record, Transfer 5 06-28-2011 01:48 AM
