10-15-2011, 01:23 AM
I Changed The "PLAY PERFECT TAPE" Settings on Mitsubishi DVHS HS-2000U- from "Auto" to "Normal" (Witch mans OFF?) and then out to AVtoolbox 8710, and then into ATI 9600 XT Capture (On WIN XP Macine),.....with MPEG- DVD Setting on MMC V8 xx... and NO Videosoap ,,But it looked worse than the Master VHS ,,,...I am on Vacation now,and will follow your guide on AVI Capture to see the results,if I get Lost,I will Send out a flair,and hope that DFAQ will guide me to the right direction!!!
10-20-2011, 01:51 AM
Normal probably means some part of the NR is off, yes.
It's been a while since I had this VCR to look at, and don't recall everything off-hand.
Need details. Worse in what way?
rocko (10-21-2011)
10-21-2011, 06:38 PM
The 2nd test capture looked "soft", with NR set to NORMAL,compared to 1st test capture, with NR set to AUTO,which was probably a SHARP NR ??,But I liked the AUTO results better. I'm Still Fiddling Around with settings and getting used to everything,But so far no dropped frames!!and My new ATI/XP machine is working Fine!! Trying some AVI captures right now,which look AS GOOD AS THE Master VHS! (But with a pattern of Tight,Vertical, top to bottom wavy lines).I will send screen shot or sample.Could be Radio or Interference from my satellite box,HDTV,Or the fact that everything (including VCR) is plugged into a UPS Power supply???
10-25-2011, 04:07 AM
Compare against "EDIT", if it has one. And SHARP.
Just be sure you're not confusing "noise" with "detail". In the photography and film world, grain often fakes detail. Human perception problems.
It's somewhat easy to exploit this psychovisual effect.
Very likely.
Thread |
ATI All In Wonder video capture card, with capture computer, for sale [SOLD]
kpmedia |
Marketplace |
1 |
05-23-2011 02:09 PM |
My inital obervations of the JVC SR-VD400US DVHS machine
NJRoadfan |
5 |
04-27-2011 08:12 AM |
Simon76 |
12 |
12-23-2010 03:46 AM |
Problems with blurry/ghost vhs clip recorded on DVD recorder
MrSupergolfer |
2 |
03-22-2010 07:52 PM |
Why are all the latest posts by admin?
admin |
General Discussion |
0 |
12-25-2008 12:32 PM |
