01-27-2012, 12:14 AM
rocko's Avatar
rocko rocko is offline
But I know it was there before, and is on my system, Also tried a capture and seemed to work just fine!, And no (!) warnings in XP Device manager. I do have the ATI 8.8 install CD,with drivers and all. Is there a simple procedure to restore capture driver,or is this a known issue with MMC 8.8? And should I even worry about it??
02-01-2012, 04:30 AM
This often happens if you have other programs open (anything using overlay) while ATI software tries to launch.
For example, you cannot open ATI MMC and VLC at the same time.
Reboot and try again. Make this the first thing you do. Does it still happen?
Video capture with horrible color noise bands? lzrplayr Capture, Record, Transfer 23 02-07-2021 04:34 PM
Recommendations to transfer video from capture PC to main PC? GroverXpup Project Planning, Workflows 3 11-24-2017 05:13 PM
AVI Test Capture has "wavy" Lines rocko Capture, Record, Transfer 7 02-01-2012 06:01 AM
Don't confuse ATI MMC Personal Video Recorder with On Demand TV! rocko Capture, Record, Transfer 1 11-12-2011 01:01 PM
Installed ATI MMC: 'Capture driver is not loaded' error? rappy Capture, Record, Transfer 11 06-27-2011 07:17 AM
