04-08-2012, 05:14 PM
Asesinato Asesinato is offline
Ive want to know if anyone knows this vcr?
SONY SLV-SE630E
Is it a good video? Does it has TBC??? And how many videoheads? Ive just found the manuel but that didnt give me any anwers, and i cant find the spec anywhere
04-08-2012, 06:43 PM
probably not good for capturing - it isnt even a S-VHS
as far as i know any Sony SLV with a number under 1000 wont be a Super.
i would stick with JVC or Panasonic
04-08-2012, 10:02 PM
Belmont Belmont is offline
I've had a good experience with my SLV-679HF. Not the best, no TBC, and really only good for casual converting and viewing (not for professional or extremely important stuff). Tracking's OK on it, but it has the annoying feature of having a tracking display come up whenever you adjust the tracking. I'd say if the price is OK (assuming you're being offered the VCR), go for it. It might come in handy for certain projects.
04-10-2012, 12:55 PM
Suggested VCRs for VHS/S-VHS conversion are listed here: http://www.digitalfaq.com/forum/vide...ing-guide.html
We don't recommend anything not mentioned on that list.
A list of Video8 / Hi8 (Sony 8mm tape based formats) is in the works, and will be appended to that page in due time.
Same for Betamax and U-matic.
Blu-Ray homemade discs - Capturing/recording to BD-R a good idea? kctexan Capture, Record, Transfer 14 03-23-2011 12:37 PM
JVC HR-S7100U VCR good for capturing VHS video tapes? lordsmurf Capture, Record, Transfer 1 08-19-2010 02:52 PM
Good video program for capturing VHS tapes John Capture, Record, Transfer 13 03-25-2010 04:55 PM
Is this DVD recorder and SVHS player good for capturing VHS/8mm tapes? ramrod Capture, Record, Transfer 1 10-12-2009 10:54 PM
Any good programs for capturing audio to MP3 ? fortunec00kie Edit Video, Audio 1 06-10-2006 11:18 AM
