02-19-2013, 03:01 PM
Medusaman Medusaman is offline
Hi,
I am trying to do some research into which VCR's might best suite my needs with regards to transferring my old video tapes. High on my current list is the Panasonic NV-HS1000 largely due to its SVHS, TBC and S-Video out. I understand that this will play NTSC format videos also. The question is - Is the NTSC signal 3.58 or 4.43. This is important to me since I will be running the VCR through a Canopus ADVC-55 which will only accept a "true" NTSC signal at 3.58.
If anyone can confirm the NTSC output I would really appreciate it.
I am also interested in the same answer in relation to the NV-FS200 also.
Thanks!
02-19-2013, 04:54 PM
NJRoadfan NJRoadfan is online now
It is likely NTSC 4.43 (PAL color carrier). If you have a stack of NTSC tapes to do, I would seek out a NTSC VCR.
02-19-2013, 05:05 PM
Thanks for the response. I have a Panasonic NV-HD630 on the way to me which is supposed to output at 3.58 or 4.43 so that might help me, but since it doesn't have a TBC or S-Video out it might not be great and so I thought I'd lookout for something better.
Your probably right and my best bet is to try and purchase one from the US and get it shipped over to UK.
Service Manual for Panasonic NV-HS800, NV-HS1000 [DOWNLOAD] juhok Video Hardware Repair 16 07-11-2017 07:33 AM
Panasonic NV-HS1000 VCR - tape ejects, has test signal? interactive Video Hardware Repair 12 01-25-2015 09:09 AM
Panasonic AG-5700E vs Panasonic NV-HS1000 for transferring tapes? tsakodim Capture, Record, Transfer 8 12-31-2014 10:00 AM
Best VCR for output quality? Gerzom Capture, Record, Transfer 6 01-11-2013 12:45 AM
Convert NTSC to PAL and back to NTSC ? admin Capture, Record, Transfer 0 07-24-2010 08:29 PM
