Quantcast What are chances an external frame synchronizer tbc improves a signal with no dropped or inserted frames in vdub? - digitalFAQ Forum
07-23-2013, 11:23 PM
quad4k quad4k is offline
When capturing some tapes on different jvc decks with internal line tbc and dnr enabled I still see some anomolies and artifacts here and there.
All the captures thus far in virtualdub show no dropped or inserted frames. I remember reading that vdub may be lying about these statistics but assuming all was well would placing a quality external frame sync tbc in the video chain improve the video? I also remember reading that external frame sync tbc are said to be for improving the signal quality and not sos much the video quality. Is there anything I can check for to verify if there is room for improvement thru using an external frame sync tbc? Or do I need to just buy some units and compare results?
AIW MPEG2 captures - dropped frame information Eagleaye Capture, Record, Transfer 3 07-18-2013 02:04 AM
A tape that can't be digitized? (Dropped frames?) moxiecat Capture, Record, Transfer 22 12-06-2011 05:57 PM
AVT-8710 Multisystem TBC / Frame Synchronizer with Color Corrector, for sale [SOLD] ieee488 Marketplace 10 10-12-2010 12:27 PM
Is there an acceptable rate of dropped frames? maphew Capture, Record, Transfer 5 06-20-2010 09:11 AM
VirtualDub - frames inserted? lookouts Capture, Record, Transfer 3 10-15-2006 09:28 AM
