08-11-2013, 02:17 PM
yellow_inspir yellow_inspir is offline
Hello all,
I am new to the forum but I have a few years of consumer-level experience with VHS to digital transfers.
I have recently taken on a project to digitize a few dozen SVHS tapes of microscopy data recorded in the 1990s.
Currently using a JVC SR-S365U on loan from the AV department. It seems to be working fine aside from the very serious problem of persistent "streaks" or "blips" appearing in the center of the image no matter what is done with the tracking settings. These artifacts are not on the tapes themselves, as they are absent when the tapes are played in lower-end VCRs. Should I attempt to clean the heads? I don't think this deck has been maintained much, if ever, during its probably very active service life.
Furthermore, the project manager would like a capture card solution that can encode the SVHS output to .mp4 "on-the-fly" in order to avoid compressing later due to time limitations.
Can any of the cards suggested here: http://www.digitalfaq.com/forum/vide...ti-wonder.html accomplish this?
Finally, do I really need a TBC for this job? The tapes don't appear to have much jumpiness but I do want them to come out as optimally as possible.
I have a budget of a few hundred dollars for this job. Any suggestions at all would be most appreciated. Thank you for reading my thread and best regards!
08-11-2013, 04:05 PM
there is probably something wrong with that SR-S365U
try cleaning it, if it doesn't help buy a better deck
do you know what deck they where made on?
The following users thank volksjager for this useful post: yellow_inspir (08-24-2013)
08-12-2013, 10:53 PM
Thanks for your interest in helping me out, volksjager.
Unfortunately, it would be impossible to track down what machine was used to make these tapes.
What I do know is they were transferred from U-Matic to SVHS at a research institution in France.
08-14-2013, 11:29 AM
This isn't going to look good at all.
It needs a quality deinterlace, and that's going to require post-capture processing.
The following users thank lordsmurf for this useful post: yellow_inspir (08-24-2013)
08-24-2013, 07:18 PM
Hi, lordsmurf. Thanks for the input. I figured that good post-processing was necessary. The priority is definitely to capture and preserve as much of the best quality video as possible so speeding up the process is a bad idea.
The following screen shots were taken from some .avis captured uncompressed using Virtualdub with a Pinnacle s-video PCI card and JVC SRS365U in AUTO and SVHS mode.
This a screen cap of part of the video. From what I have read about it online, the image seems to exhibit the infamous JVC "comet" issue.
Here is another screen cap of the same tape taken immediately after a cleaning of the video heads using a PreSat 99% IPA-soaked foam swab. The comets disappeared only to return almost immediately after this video was taken. My guess is that the static electricity accumulated between the upper and lower drums of the video head that is said to cause this issue was temporarily dissipated during the cleaning. It only took minutes of operation for the static to return.
For comparison, here is a screen cap from a video of the same tape recorded from a JVC HRS5901U in SVHS and AUTO mode. I can immediately see the difference in quality between the VCRs.
So now I want to try to repair the JVC SRS365U. From the service manual, I see the static brush assembly pdm4440a is the part in question. It seems to be available from many suppliers online for about $6.05. Will a replacement brush solve the problem at least for an extended period of time sufficient to capture these tapes? Maybe cleaning the existing brush will suffice?
I see that a realignment is necessary after disassembling the video head. I have experience with an oscilloscope and access to the necessary cables. However, I have no idea how to obtain this MHP alignment tape. It doesn't seem to be sold anywhere.
Advice for converting VHS-C tapes, Panasonic vs. JVC VCRs? Tomas84 Restore, Filter, Improve Quality 27 02-08-2018 09:12 PM
Converting home movies -- need advice Jpass992 Capture, Record, Transfer 10 07-17-2013 08:04 PM
Newbie: Where to begin converting VHS tapes to digital ? kd19 Project Planning, Workflows 6 02-10-2012 09:42 AM
Advice Converting VHS to Hard Drives with Quality in Mind mguitonxlt Project Planning, Workflows 4 11-11-2011 05:44 PM
Proper equipment for converting and restoring video? privategomer Project Planning, Workflows 24 03-16-2010 11:30 AM
