Quantcast Newbie Capture Question - digitalFAQ.com Support Forum
Go Back   digitalFAQ.com Support Forum > Digital Video > DVD Project Help > Capture, Record, Transfer
05-16-2004, 05:09 AM
teac teac is offline
Currently I have a DAC-100 and capture via 1394. Is there an advantage to capturing with DV RaptureRT or a Matrox capture card?
05-19-2004, 12:09 PM
admin admin is online now
You're talking the difference between a consumer card and professional cards (which, yes, can do much more).
Now, whether you need pro options is another question. What kind of work are you wanting to do, and how much money are you willing to spend?
Also, be sure you put in money on good playback equipment (VCR, TBC) before jumping to higher pro cards.
__________________
If this site has been as helpful as a book or magazine, then Donate a few Dollars or Upgrade your Membership.
05-19-2004, 12:22 PM
Im not sure I am capturing with a card now. The DAC-100 is an analog converter. I capture with Let's Edit Software.
I just ordered a JVC HRS-9900 (thanks to your forum)
05-19-2004, 01:18 PM
The DAC is a DV capture device. It captures analog material and makes it digital.
It's limited to DV-only input. It's not like an ATI card (for example), that can capture with any native AVI codec or even MPEG directly.
I have a Matrox card on my wish list, but I'd use the MPEG capture for quick projects, and the DV capture with realtime editing/output for more advanced work. I want to do that in the future, early next year I think.
__________________
Newbie help - take recorded videos and stills, put them together mags102 Project Planning, Workflows 4 08-11-2006 02:18 PM
Questions before you join? admin General Discussion 0 06-08-2005 02:01 AM
Various Questions and Some Observations mitch Capture, Record, Transfer 18 03-16-2005 12:15 PM
Newbie Burning Question dminches Author, Make Menus, Slideshows, Burn 1 12-10-2004 11:29 AM
ATI Card vs. Recorder, Etc. (newbie) mitch Capture, Record, Transfer 5 05-29-2004 06:15 AM
All times are GMT -5. The time now is 02:22 PM  —  vBulletin Copyright © 2011 Jelsoft Enterprises Ltd  —  SEO by vBSEO
