05-21-2014, 05:36 AM
geomiga geomiga is offline
Just to confirm, you can not use the AG-1980's TBC to correct the signal from other devices? That is, for example, to feed another VHS tape in to the 1980, and then use the 1980 s-video out's to send a nice clean signal out to a capture device?
I was hoping to save a purchase of a stand alone TBC by using the 1980's.
I will have to pry open the boxes that contain my old Video Toaster and see if I can get the DPS TBC IV cards working...
05-21-2014, 05:45 PM
According to the user manual, "The TBC function only works during normal playback."
However, playback of the VHS tape in the AG-1980 could benefit (if the unit does not suffer from failing caps.)
As proof of the pudding with your specific source tapes and VCRs, give it a test to see if it has any beneficial effect. While the TBC may not be operating there might be some other beneficial effect.
06-03-2014, 05:23 AM
Correct. It does NOT work on passthrough. It only work on VHS or S-VHS tapes that are being played back on the deck.
If you need a passthrough capable deck, then look at the Panasonic ES10 through ES25 series.
Look in the marketplace forum: http://www.digitalfaq.com/forum/marketplace/
In fact, one of our members has one on sale right now: http://www.digitalfaq.com/forum/mark...sonic-dmr.html
What sort of error are you trying to correct?
Panasonic AG-1980 alignment? videonut Video Hardware Repair 2 11-26-2013 12:21 PM
Panasonic DMR HS2 DVD Recorder as a pass through for bad quality tapes? Urbane0083 Restore, Filter, Improve Quality 8 09-30-2013 02:58 AM
Looking for a Panasonic AG 1980(P)? Duberg Marketplace 1 03-04-2013 03:15 PM
Using the Panasonic 1980 sharpen cyber-junkie Capture, Record, Transfer 13 03-25-2010 06:37 PM
Panasonic AG-1980 as good as JVC S-VHS VCR ? ramrod Restore, Filter, Improve Quality 1 11-13-2009 07:33 PM
