07-16-2014, 03:24 AM
Quasipal Quasipal is offline
The more I work with and read about the Panasonic video recorders I find myself wondering why the ranges differed so much for the two regions. Whilst Europe had the FS200 and the US had the AG1800 (which are said to be compatible) the FS200 with it's G mechanism was already discontinued when the AG1800 was launched (with it's K mechanism). The AG1800 was also a long production run item but in Europe models were launched every two years. So from 1995 to 2003 we had (in order):
HS1000
HS900
HS950
HS960
Which ran from the K mechanism to the Z mechanism.
Also whilst all the AG1800 machines are having bad capacitors, the capacitor issue was resolved in the European range with the discontinuation of the FS90 in 1992 with even early examples of the FS200 being fine over 20 years later.
I don't think that the US even got a Panasonic S-VHS deck with temporal noise reduction (Europe had four or more) and some of the later US Panasonic's have a mechanism that was never used in the European range (what was it's designation?)
I'm left wondering why the two ranges were so different and why things like bad capacitors were being used when that issue was already known and dealt with in other countries. Also why didn't the European range have a long term machine like the AG1800 in their catalogue?
07-17-2014, 08:44 PM
I'm not readily familiar with an "AG1800" model. I think you mean the Panasonic AG-1980P (and the tunerless AG-5710 variant of the 1980).
The AG-1980P was equivalent to the NV-FS200.
Image quality
There was no NTSC equivalent to the NV-HS1000, with is frequently reported as being slightly better than the FS200/AG1980 in image quality. Audio quality is still the same (which is excellent, better than the JVC line).
However, all Panasonics are still slightly inferior to JVC image quality, nuder typical conditions. There lots of if/or/but caveats here. So sometimes the Panasonic is better. It depends on the source. It's why most all professionals and serious hobbyists need both kind of decks, as they're different. Even within the same brand/manufacturer, the models lines vary -- as it does with the HS1000 and the FS200/1980.
The TBC integrates temporal NR. That's the main reason for debates concerning quality. The Panasonic tends to be more limited compared to the JVC, which is one reason the image quality between the brands differs. Same for Mitsubishi and some others that you rarely hear/read about.
More Panasonic S-VHS models?
The reason for the PAL 900s Panasonic model was likely no more than production runs. The AG-1980P had a long, long model lines, ranging from the early 1990s to around 2006. I forget the exact dates. In all honesty, the AG-1980P had so many variations that it should have been broken down into separate models (1985, 1990, etc).
Bad caps
The issue was never resolved. It's a worldwide epidemic that infests many devices -- not just VCRs. We just hear about them less, but it's very common. If anything, the older FS90 does not have the issue simply due to its age, as the problem is almost entirely from the 1995-2005 era. The issue was not publicly discovered until the mid 2000s, and by then it was too late. To this day, most manufacturers still deny the problem. Several lawsuits have ensued, and I'd not be surprised if some were still ongoing.
If any EU/PAL models were spared a capacitor issue, it's like happenstance, and was not intentional. For example, sourcing more-expensive parts from other EU or Asian countries, not the far East. I know that many JVC S-VHS VCRs were entirely built in Germany, and likely used local parts back then. It was just a different era for world commerce, and the infestation of dirt-cheap (unsafe! bad!) Chinese parts/products has not yet hit.
Best places to get JVC/Panasonic S-VHS VCRs repaired? kpmedia Video Hardware Repair 49 01-28-2022 07:44 PM
Advice for converting VHS-C tapes, Panasonic vs. JVC VCRs? Tomas84 Restore, Filter, Improve Quality 27 02-08-2018 09:12 PM
Panasonic AG-1980P VCRs won't power on kpmedia Video Hardware Repair 2 09-30-2013 02:54 PM
Manuals for Panasonic video restoring gear - DVD recorders, VCRs [DOWNLOADS] robjv1 Video Hardware Repair 1 09-01-2010 12:57 AM
