Quantcast 9600 AIW captures excellent, but authorware wants to reencode ? - digitalFAQ.com Support Forum
Go Back   digitalFAQ.com Support Forum > Digital Video > DVD Project Help > Capture, Record, Transfer
06-10-2004, 04:32 AM
-d00d- -d00d- is offline
Hello All, I am getting good captures when I have good source. The resulting mpeg2 file is around 2 gigs on disk but when I import the file into the dvd authorware it indicates the file as being twice the size. I am capturing using the settings advised on the capture guides Lordsmurf has on his website. Am I missing something? Also it seems that the authorware in question transcodes the video when it is already in mpeg2 dvd format, that seems odd as well. Software in question is Roxio EZ dvd/cd creator.. (Perhaps the culprit).
Any ideas?
Thanks...
06-10-2004, 05:18 AM
Roxio is burning software only. Anything else (like authoring, capturing, etc) is horrible. You need real authoring software. Something like this:
Sonic DVDit! (www.sonic.com or www.dvdit.com)
Pegasys TMPGENC DVD Author (www.pegasys-inc.com)
Sonic ReelDVD (www.sonic.com)
Mediachance DVD-LAB (www.mediachance.com)
Ulead DVD Workshop (www.ulead.com)
Adobe Encore (www.adobe.com)
TMPGENC is cheapest.
I prefer DVDit! for most of my work.
Roxio is wanting to re-encode you video to what it THINKS it should be. This is HORRIBLE. These other programs will use your files as is, unless they are not compliant with DVD format (see the various capture guides for compliant DVD specs). If you're following one of my ATI capture guides, then you'll have DVD-ready MPEG material.
__________________
- Did my advice help you? Then become a Premium Member or make a donation.
06-10-2004, 05:22 AM
I thought that might be the case, thanks LS or Lord or whatever you want to be referred to as
06-12-2004, 01:50 PM
jrnyhead jrnyhead is offline
Darn, too bad there is not a trial version for DVDit!
06-12-2004, 01:58 PM
admin admin is online now
Yeah, that's really a shame too. It's quite nice. I'm really happy with version 5 that came out a week or so ago. Bought the upgrade. Motion menus, multi VTS, fast AC3 encoder, the works (except subs and dual audio).
On the other hand, Adobe has FINALLY put up a demo of Encore. I noticed that the other day.
__________________
If this site has been as helpful as a book or magazine, then Donate a few Dollars or Upgrade your Membership.
Please help with MainConcept settings for VHS Captures jrodefeld Encode, Convert 4 08-30-2011 01:29 AM
ATI All In Wonder 7500/9600 vs ATI 600 USB - Which is best? lordsmurf Capture, Record, Transfer 0 09-27-2010 05:50 PM
Is there still hardware that captures in avi, for VHS and Hi8 admin Capture, Record, Transfer 0 08-23-2010 12:15 PM
Purple band on AIW TV and Captures Jerome Capture, Record, Transfer 12 04-30-2005 09:06 AM
All times are GMT -5. The time now is 02:31 PM  —  vBulletin Copyright © 2011 Jelsoft Enterprises Ltd  —  SEO by vBSEO
