Hi again guys!
I'm back at work on this. As said, I got everything setup. I captured lots of videos from 8mm using
virtualdub and lagarith.
Now I'm into avisynth and QTGMC and more.
I would like good video playback on a computer (I will probably keep unprocessed files as archive, in case I would like TV playback someday). From readings and your suggestions..
For the deinterlacing, it seems like you're saying you put the script into VirtualDub and created an AVI output using Fast Recompress, then encoded that using x264. You don't need to do that; you can feed the Avisynth script straight into x264.
x264 + MP3 is a weird combination. x264 + AAC would be the typical configuration, and AAC is a more efficient audio compressor.
I concluded X264 and AAC would be a good way to go, done in my Avisynth script along with QTGMC. (Unless you recommend something else!)
Is that possible? To sum up, I'd like to take my "uncompressed" Lagarith captured avi file and get to the desired result, in 1 operation.
Thanks in advance
PS: I saw all your proposed scripts before for correction, but I don't know if I'll have the patience to learn and master everything. I'll see during the process (I have 2 young children, and my free time is somewhat limited heheh). I think the new captures with ATI TV THEATER 500 look not bad (or better than previous captures!)
