08-18-2015, 08:24 AM
Goldwingfahrer's Avatar
Remembered
-> Generating calls for: C:\Users\Shandor\Desktop\HomeMovies\MP4\test2.mp4
C:\...Target = no
another hard disk
but I have shown only the basic settings in the film
in 2.Film I show then how to work
but have at the moment a lot of work
give me a small excerpt from the film.
I try then
08-18-2015, 08:40 AM
ozigoo ozigoo is offline
Thanks LS, might give it a try as Hybrids giving me a headache...lol
Goldwing I dont have another hard disk only C on my laptop..=/
Very late now here in Australia...going to bed...tomorrow post small raw movie data
Thank you again for your help guys....much appreciated
Guten Nachmittag
08-18-2015, 10:46 AM
Remembered
possible that Anton Strauss can help
I met Anton Straus from the Grass Valley Video Forum [Edius]
he is very helpful
http://www.videoproductions.com.au/html/about_us.html
""HybridDebugOutpt.zip""
send it directly to Selur
http://www.selur.de/support
I'm just a user
08-18-2015, 07:59 PM
Hi again, so I gave up on Hybrid and tried Avidemux (64bit)
Its different from the guide and doesnt have many changeable settings
so I used the basic settings as in the pic... (Yadif deinterlacer)
Got an error box "Cannot setup codec, bitrate too low"
EDIT: Tried HEVC(x265) and its now processing..let you know how it turns out
HEVC didnt work but MPEG4 AVC (x264) does...maybe this is the one I was meant to use first?...lol...
looks pretty good so far....cheers
Thanks Goldwing... Selur has been helpful but still no success with Hybrid
I downloaded Avidemux as LordSmurf suggested and have had success with that so far.
I might continue playing with Avidemux
Thanks again
Regards
08-19-2015, 06:36 AM
Remembered
Yes, avidemux 32 + 64 bit I have.
The yadif deinterlacer is not available for all movies
my test setting, see screens
QTGMC or TGMC is better
I have a small clip as compared from avisynth expert users didee
in my archive.
As you can see various deinterlacer at work
08-19-2015, 06:57 AM
Feel free to shared the archive of clips as attachments.
08-19-2015, 07:42 AM
Remembered
3 clips of didee from my archive...[korrekt is Didée....otherwise I get here a blow to my head;-)
OT = a
test an old Converter
OT = Off
File Type: avi StockholmA_0-520_Q3_Yadif_MVBobMod_TGMCa4_TDTMM.avi (97.44 MB, 17 downloads)
08-19-2015, 08:01 PM
Thank you Goldwing,
Amazing I must be learning, have mine setup very much the same...
I tested constant bitrate single pass and average bitrate 2 pass encoding but very little visible difference (on my 55inch Samsung LED TV) in visual quality for me and the file size ended up twice as large with 2 pass...so I stayed with single pass
I tested Audio ACC (lam) and Audio AC3 (Lam) and found AC3 slightly clearer on my surround sound system
I have found a problem when loading a new video after one finished.
All the video and audio configuration settings are lost? and the audio setting sort of freezes.
But once I redo all the settings the audio configuration unfreezes?
Also the Queueing doesnt seem to work for trying to process multiple video files one after another
which is really bad because I have alot to process.
Ive looked for a solution at the Avidemux Forum but i think its a bug..if I cant fix it I may go back to trying to
get Hybrid to work as my confidence and learning is increasing exponentially and Hybid has better support...
Thanks for the support
Regards
08-19-2015, 08:20 PM
OT = a
OT = Off
Wow...TGMC looks amazing...
Can you put TGMC or QTGMC into Avidemux as a Plugin or do you need AVISynth and thus Hybrid again...lol..?
http://forum.doom9.org/showthread.php?t=156028
Cheers
08-20-2015, 11:41 AM
Remembered
I rarely work with AviDemux.
Question but has Lordsmurf..er you AviDemux recommended.
Interlaced to progressive I take Avisynth, separately.
Hybrid I suppose even if the stream [AVC + AAC] is to be encoded in interlaced, so MBAFF.
In hybrid I have not installed Avisynth.
I'm old fashioned ... just a dinosaur.
08-20-2015, 12:36 PM
You can only use Avisynth for most advanced deinterlacers. Avidemux only includes yadif.
DVD+R disc don't play in player? ninjastriker Videography: Cameras, TVs and Players 11 02-21-2016 03:22 PM
Standalone player will not play DVD? Chala Copy DVDs, Duplicate, Replicate 1 09-19-2010 09:30 AM
Blu Ray BD-R Disk won’t Play Kent Blank Media 5 03-09-2009 11:28 PM
Play avi's on computer? rockettj1225 Videography: Cameras, TVs and Players 3 11-11-2008 04:49 PM
DVD won’t play on some players Edye Author, Make Menus, Slideshows, Burn 3 11-21-2004 11:50 PM
