11-24-2015, 07:19 PM
LFonseca LFonseca is offline
I'm having problems using my capture card, with XP, with my lcd. The lcd has a native 1080p resolution. The ati supposedly supports it - 1920x1080 - but when I set this resolution the monitor goes into "not supported" mode. With a different PC it supports 1920x1080 just fine. Anyone had any similar problems with a 9800 board?
Thanks!
Luis
11-24-2015, 08:42 PM
I've run into this, and it's really annoying.
The ATI AIW 9800 is fine with a 1920x1080 LCD. I use 1080p monitors for all video work.
The problem here can be:
- display drivers (most common)
- Catalyst/capture drivers
- ATI MMC version
- BIOS battery weak/dead
- DVI or VGA cable (less common)
- power supply (least common)
I've been building some ATI capture systems in Sept-Nov, and I've seen this several times on my non-1080p test monitor. So 1080p isn't the issue.
11-24-2015, 09:42 PM
Could you let me know what are the best driver versions and mmc version for this board? I'm using this:
ATI All-In-Wonder Setup (180-V01084-100).part1-13.rar
Is there a better choice for this board? I've also tried current display drivers but then capture no longer works and 1080p is still not supported - it goes into a weird scrolling mode, where not all the screen is visible at once...
I'd prefer trying software before proceding to the hardware.
Bios battery is a really, really, really, really weird cause! I'm not doubting you, I'm just struggling to figure out how it could possible come into play...
Thanks again,
Luis
11-24-2015, 11:07 PM
ATI MMC 8.8 seems to work best on 9600-9600 cards.
Same here on the BIOS battery. No idea how that came not play, but it did. At most, I'm guessing it wiped out some AGP settings that the card needed for that specific motherboard. The clock didn't work, SATA drives would not boot, and the video card went wacky. New battery, problem solved.
I'll have to check on the drivers. But, in general, the "6168" drivers are best. See those in the ATI driver thread.
Which drivers for ATI All In Wonder 9800 Pro? david151 Capture, Record, Transfer 7 06-30-2012 02:35 AM
Replacement for ATI AIW 9800 Pro? admin Capture, Record, Transfer 0 05-06-2009 04:33 PM
ATI 9800 AIW manthing Capture, Record, Transfer 8 07-05-2005 01:22 AM
AIW 9800 Pro MV Edye Capture, Record, Transfer 3 11-21-2004 05:41 AM
AIW 9800 PRO strangepork Capture, Record, Transfer 10 10-21-2004 10:44 AM
