12-26-2015, 04:05 AM
BoBi1234 BoBi1234 is offline
I would like to record tv signal using my HDMI capture card and save it directly as h264, what software and configuration will be best on i7 3930k?
12-26-2015, 04:29 AM
Goldwingfahrer's Avatar
Remembered
is not that enough ?
https://www.blackmagicdesign.com/pro...264prorecorder
  • Media Express Software Included: Blackmagic Media Express is included free with H.264 Pro Recorder. Media Express lets you batch capture your H.264 files with an attractive user interface that's a pleasure to use, even after hours of encoding work!
http://www.amazon.com/gp/product/B00...VXYSVHQXVFJRL6
12-26-2015, 04:39 AM
Thing is I dont want to spend 500$, i have hdmi capture card but without hardware h264 encoder. I can record to huffyuv and then encode to h264 using MediaCoder but i would like to record directly to h264.
12-26-2015, 04:49 AM
Remembered
directly into x264 [H.264] I know nothing
in ancient times was that with the MainConcept References
I also have a card with HDMI in and out
plus SDI in and out
Blackmagic Studio 2
and
Matrox MXO2 LE is
I save my movies on TV
not from in x264.
Only these films must be cut to remove, by filling pixels and Teletext entries.
end result
addendum -- Whether directly dips into the free x264 vfwx264 I do not know. See image in VDub
12-26-2015, 06:54 AM
Unlike the MPEG era, there's no way to capture H.264 in software. And even in the MPEG days, software capture was terrible. You needed hardware encoding, or hybrid hardware encoding (ie, ATI AIW).
HDMI input is not cheap in resources, or in price.
Most use some sort of Hauppauge card to capture HDTV. I'm not sure of the input, however. I doubt the lower-cost cards have HDMI input.
12-26-2015, 07:48 AM
I think U are not right, using AmaRecTV i partly done it. I dont have audio in my file but video is captured.
12-28-2015, 08:09 AM
Remembered
Go to image
Laczego = warum [German] = why [English]
"Ja" [lower left of the image] is not a Polish word [my wife says, the read and write Polish]
there are exceptions
Canopus Fircoder blue
or
per HDMI in
Blackmagic Studio [HDMI or SDI]
MainConcept Reference capturing directly into x264 [H.264]
AVC and AAC
[tested in 2011]
see pictures
12-28-2015, 10:08 AM
pinto pinto is offline
"Dlaczego ja?" means "why me?"
12-28-2015, 11:52 AM
Remembered
correctly.
Only had to turn on our brains.
ups ... we grow old
przepraszam
Recording YPbPr on VHS jmac698 Capture, Record, Transfer 4 01-08-2011 04:11 AM
Need a DVD Recorder for Recording VHS to DVD Konfusion Capture, Record, Transfer 8 04-11-2010 06:13 AM
Recording time on DVD-R? genebender Blank Media 1 02-08-2009 12:14 PM
MP3 recording question!!!!!! MOTUfan Edit Video, Audio 2 11-21-2005 05:17 PM
The history of recording tv lordsmurf Videography: Cameras, TVs and Players 3 06-28-2005 01:23 PM
