VCR won't stay on, LED blinking?
I have a vcr from 2000 called LG AC901NP. I was planning to use this unit to capture old tapes, but it won't stay on after I hit power. The red power led starts blinking along with the timer and then it turns off.
If I hit power again nothing happens. I need to unplug and replug the power for it to once again turn on, blink and die. The manual is long gone and LG, like any other company, doesn't publish old manuals. Is there perhaps a way to troubleshoot this? Could the number of blinks be a clue a bit like BIOS error codes or is that wishful thinking? |
Honestly, it did you a favor. LG VCRs are not good at all, and would only have given you low-quality captures.
Be sure to read this: http://www.digitalfaq.com/forum/vide...ing-guide.html While the number of blinks may have meaning, I doubt it would do you much good at this late post-VHS date. |
Oh that's disappointing.
I've been looking for vcr's from that list but there are not many around. I'd prefer to buy it within my country(Norway) due to shipping costs but so far I've only found one vcr and it's faulty(spits out tapes). I might find some on Ebay but the UK ones have different plugs, 110v I'm guessing. |
USA is 110, UK is 220.
As far as a I know, most EU countries have the same power rating, and just need plug shape adapters. The JVC S-VHS (example: my HR-S7965EK) line actually has worldwide power, and even in the USA only needs a plug shape adapter. |
Aha, that makes it a bit easier. Still, worried about getting a dud. And shipping is super pricey, and then comes import taxes and handling fees. Tough decision.
I import (and sometimes export) stuff from all over the world on a regular basis. Shipping is expensive (though not as expensive as you might think), but it's always worth it.
Maybe. It's just that they add shipping costs as part of total price when they calculate the 25% import tax here. And their fee is $20 on top of that.
Also, is a tbc required for camera videos? |
A TBC is required for analog video, regardless of the source (home camera, retail tape, etc).
I found a JVC HR-S7700 and a Panasonic NV-SV 121 on Ebay. Seller wants the same amount for both of them.
Is it a given to pick the JVC? I have to ask since it's not on the recommended list. |
The 7700 is probably a 7600 successor. If you look further down that buyer guide, perhaps even on 2nd/3rd pages, a fuller JVC listing is shown. I've not yet had time to overhaul that list as needed. I was in the middle of doing so, earlier this year, when I had some health issues, and I just never returned to it. Yet. I'll try again this spring, when I get some free time.
Ah ok. I also found a HR-S6600 for half the price but it has no tbc as the list-topic says. How important is that tbc when you have an external one as well? Does that vcr have other features that perhaps can mitigate the lack of internal tbc?
An internal line TBC does a different task than an extenral frame sync TBC.
A TBC-less VCR should only be used for tapes that have no chroma noise, no grain, etc. Essentially studio-made tapes. |
Right. So I decided to contact a professional due to the significant cost of the equipment needed.
I asked if he could transfer to huffyuv with yuy2 colorspace, which I read somewhere on this forum was optimal if final source was to be a bluray disc. He replied he only transfers to the dv format. His setup includes a JVC HM-DR10000 -> Datavideo TBC-1000 -> Sony DSR-20P. Then he transfer to pc via firewire. The dv files are then sent to me on a harddrive. He has fairly reasonable prices. Should I go for it or look elsewhere? |
I put the HM-DR10`000 .... and TBC1000 then you go from there to SDI. Directly in DV-AVI whether Microsoftt DV-AVI or Canopus DV-AVI was formerly used at times Pentium 3 and that's 20 years ago. Analoges never capture to DV-AVI always in Lagarith or Huffuv |
I suspected as much. The search continues...
1 Attachment(s)
Sorry I did not mean to be unkind
DV-AVI is okay if mini DV or DV-AVI big bands present. Here's a little picture ... currently on a Capture Station. The TBC1000 I just put down that I need rare. Although I can not speak English but sometimes cry when I see how people digitize analog films. |
Years ago I captured a couple of analog tapes with DV equipment. I will never do it again. What a nightmare to clean up VHS to DV. |
Contact us: http://www.digitalfaq.com/forum/sendmessage.php A lot of "professionals" (not really a professional) are just doing this on the side, and have no actual real-world experience beyond their own home movies using techniques they found online (likely from this site and VH). So you're giving your precious tapes to somebody that may only know as much as you do, or possibly even less. Beware. Yes, Huffyuv 4:2:2 to MPEG-2 4:2:0 for Bluray is optimal. Though depending on the source, end format goals, and capture hardware, sometimes direct to MPEG 15mpbs may be fine. (And this is why you seek a professional. They can help.) |
I might just do that. Will have to check with the family how much they're willing to spend.
Do you have people in Europe? |
For an in-Europe person, Goldwingfahrer may be able to help you out. (Switzerland) |
