09-09-2016, 01:41 AM
Hi
I have a problem
I have the S9500MS JVC, if I activate the integrated TBC , I have black at times (1 second).
if I disable the I don't have this problem but I have noise and the picture is less beautiful. Why? Thank you
09-09-2016, 01:54 AM
MS = multistandard (PAL, NTSC, SECAM)
Are you converting the signal format? It may be the units going through some gyrations to both switch formats AND the TBC.
09-09-2016, 01:58 AM
I don't have format problem, MS is multistandard.
but I have a black dropout (1 second) sometimes.
09-09-2016, 02:02 AM
Yeah, correction: multistandard. PAL, NTSC, SECAM.
Are you converting standards when that happens?
And is it only when you enable or disable it? Or just random times?
Are you 100% sure it's not the source tape? How are other tapes?
What format? SECAM? (I see you're in France.)
09-09-2016, 02:10 AM
I have no problem with the multistandard system.
I have colour images PAL, no automatic. When I turn off TBC I have no problem , so the problem comes from TBC
I wonder if the integrated tbc is highly efficient ?? . I bought this vcr just for that.
