Sanlyn
Thanks for going to the trouble of attaching the PDF guide for the AIW X1800 series cards. I read it carefully and especially took note about verifying load of PCIE drivers and removing prior display drivers. I had already done that.
I note some differences between the card pictured in the PDF guide and my XL1800 GTO Card. My card has (2) DVI output connectors and (1) F type jack RF in receptacle and (1) DIN style ATI proprietary purple AV input adapter jack (same as I use on my ATI All in Wonder 9600 card on another machine). The one pictured has (1) DVI output receptacle and (2) F type jack RF inputs as well as uses a SCART style adapter.
Searching the internet I found this statement regarding the X1800GTO from a website called Legit reviews dated 2006.
{Instead ATI took their R520 core and did a number of modifications to the card to cut back performance and the price tag. With an MSRP of $249, the X1800 GTO is essentially a modified Radeon X1800 XL GPU with fewer pipelines and ROPs. Here, we see a slight decrease from 16 pipelines down to 12 as well as a drop in Raster Operator Units (ROPs) from 16 to 8. Other than these changes the X1800 GTO retains all the features and functionality of the full Radeon X1800 series of GPU’s}
I will try some earlier capture drivers to try to get the composite/SVideo swap and color to work right, also maybe I am using the wrong AV input adapter jack. Any guess as to which specific capture drivers/codecs I might try for ATI T200 Unified AVStream Driver. I think my display drivers are not a problem would like to try using just a minimum of drivers from ATI then use Virtual Dub on this machine for capture.
I did capture now with
VirtualDub with same results of black and white capture from a color tape and had to select SVideo in VD to see my composite input. Good thing to get acquainted with and practice with
VirtualDub so progress me thinks.
Your VirtualDub guide is outstanding!!
I bought an SVHS VCR yea its an eBay machine so It might be stupid on my part but as I did repair VCRs and TV's (including tube tv's) back around 79-83 it gives me maybe too much confidence in taking on something like this. its a JVC HR-S2901U and its supposed to work great.
laughing hysterically
