Originally Posted by Fred Fumanchu
Can the filters be applied to the files after the videos are captured, or are they applied during the capturing process ?
Which filters? You mean denoisers, color correction, sharpeners, chroma noise cleaners? Other cleanup tools? They are are
always applied
after capture,
never during. If you refer to brightness and contrast controls that manage input signal levels, they are adjusted and applied during capture to avoid invalid or illegal video levels.
By the way you say...
Windows 32-bit 9x/NT/2000/XP/Vista goes under C:\Program Files\
Windows 64-bit XP/Vista/7 goes under C:\Program Files (x86)\
Isn't it the other way around?
No. The (x86) designation is for 32-bit programs installed in 64-bit systems.
I'm surprised that you didn't notice the other anomaly:
Windows 32-bit dll's run in 9x/NT/2000/XP/Vista goes under C:\Windows\system32\
Windows
64-bit dll's run in XP/Vista/7/8/10 under C:\Windows\system32\
Windows
32-bit dll's run in
64-bit XP/Vista/7/8/10 under C:\Windows\sysWOW64\
