Hi, having trouble capturing Direct TV
I'm running XP Pro 3.06G P4 processor AIW 8500DV Video Card.. It was working fine until I installed a 2nd larger hard drive.. now at various times it will stop recording usually before I hit the 3min mark If I set the quality to VCD it will go longer before stopping.when I run the PC check it tells me the audio clock isn't quite there, but also one of my hard drives may not be DMA enabled. When I checked in Device Manager on my original hard drive tranfer mode says DMA if available Current transfer mode say PIO mode. Is this my problem? If so, how do I enable it? |
Change it to DMA. In Windows XP, that drive mode is a selection list.
DMA is one problem. The second problem sounds like you're out of hard drive space. You're probably still capturing to the primary drive, not your new secondary, and beyond that, the recycle bin may be full (empty it). If you have a special "trash manager" be sure it is not reserving space (Norton Protection, part of Norton Utilities, is one example). Change your hard drive location in ATI MMC by going into the ONE TOUCH RECORDING and change the location where it saves files. The ONE TOUCH settings are MMC-wide. Try all this then get back to me. |
