09-22-2017, 09:04 AM
As I await other hardware...is this machine magnavox zv427mg9 I can get for $50, anything good about it?
Owner says it's almost new, barely used, only for taping sermons on Sundays...
09-22-2017, 09:33 AM
Junkware made by Funai. Utiitarian at best, use only for recording directly to DVD for material of no or little importance. Typically horrid tape player, even if it works. Why do you want it?
09-22-2017, 10:30 AM
Just as a backup if it had any merit. Just as well. Waiting on my bid to win an ES15. Thank you.
09-22-2017, 11:32 AM
If you mean using the Magnavox as pass-thru tbc, not all DVD-R's can be used as pass-thru. Even if it did work this way, the ES10 and ES15 are far more powerful for that purpose.
09-22-2017, 12:41 PM
Magnavox had a well-deserved nickname: Maggotbox.
magnavox
Magnavox HDD/DVD recorder any good? premiumcapture Encode, Convert for discs 3 05-01-2014 07:19 AM
Magnavox DVD player to a Magnavox recorder, won't work lordsmurf Capture, Record, Transfer 0 08-20-2011 09:39 PM
Magnavox H2160MW9 any good? lordsmurf Capture, Record, Transfer 12 04-02-2010 01:23 AM
Magnavox H2160MW9 overscan ieee488 Capture, Record, Transfer 19 03-16-2010 07:49 AM
