09-05-2017, 03:41 PM
dtk17 dtk17 is offline
First off thank you to everyone on this forum. Been lurking for about a month and have learned a lot.
I received a vhs tape in the mail today and it looks like it had a rough ride. The tape arrived with a crack along the back end with a piece missing. Nothing is rattling inside. The seam along the back seems broken and it also seems to run under the label. I've included a few pictures.
Is this safe to play? I just need one play to transfer the tape. Would taping or gluing the broken areas hold up for a single play?
09-06-2017, 12:33 AM
Dude111 Dude111 is offline
Wow she looks quite damaged....
Try putting some tape around the cartridge to holf it together OR transfer the spools into another shell...... (I hae done that before)
Good luck....Im so sorry
10-09-2017, 11:14 PM
If it were just a crack, I'd tape it and capture.
But you have some missing shards of plastic. Are those inside the tape, or out? Don't guess -- know. The only way to know it to open it and see. Remove any shards that you see. Verify that none are lodged between layers of the tape in the spools.
After that, sure, tape it good.
I have spare blanks solely bought for parts. I'd just replace it, if bad.
No glue.
vhs
Problem with VHS to DVD playing on different players CarolJoy Capture, Record, Transfer 6 10-10-2012 01:21 PM
How to copy DV tape to new DV tape with audio removed? via Email or PM Edit Video, Audio 1 09-13-2012 05:55 PM
Best TV for playing LaserDisc videos? Jpass992 Videography: Cameras, TVs and Players 5 07-16-2012 10:52 PM
DVD not playing back and freezing up SALSCO1 Blank Media 1 12-28-2011 06:29 AM
VHS tape malfunction, mechanism not rolling tape properly admin Capture, Record, Transfer 0 10-12-2009 10:57 PM
